Ana içeriğe geç
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
20 Soru Tümünü görüntüle
I need help please...
Hi my 2005 chevy equinox is making like a low rattling noise while idling on park.its kind of annoying i just did an inspectiin and passed. If i hit the gas it goes away but while idling it does it what can it be? Please help other than that the car working wonderful. I had just changed all my mount, oil pan gasket, changed oil, did a tune up changed the breaks and ran it thru diagnostic no codes. Don't know what else to do.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
usually when you add a higher RPM noises tend to go away or get quieter.
you said you changed all your mounts? do you mean motor mounts?
i would get it up in the air and double check everything you touched or take it back to the shop you had it at and have them verify tightness all around.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
sounds like you disconnected something and forgot to reattach. Retrace your step as if you were going to perform the work again. I assume you removed the motor mounts to change the oil pan gasket. did you unhook the exhaust? It often has a heat shield of thin metal that might product a ‘rattling’ if not reattached.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Milagros Rivera sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 104
