820-00165 shut off after 5-10 minutes of starting time
I have 820-00165 which shut it self off after 5-15 minutes:
I thing its Processor short to ground as C1031 shorted to ground 29 Ohms. need expert view please.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I go with battery first. A weak battery can show a full charge, but drop to 0 quickly. Then monitor temps. If CPU temp is over limit, it will shut down.
Bu yanıt yardımcı oldu mu?
29 ohms to ground is not considered a short on the Vcore (CPU) rail.
Test with a known good magsafe (original is preferred) power adapter. It is ok to remove the battery and test with the external power adapter only. Does the logic board power up and remain to be powered with the external adapter ?
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 147
3 Yorum
This sounds like a weak battery, let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Dan tarafından
Battery 110% ok. Battery changed then charger changed. SSD changed. Housing changed. But no luck.
shafiq tarafından
@shaf2u - Lets get that CoconutBattery snapshot please
Dan tarafından
