Still use iPhone 8 Screen?
Does the SE 2022 still use the same display module as the iPhone 8?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
From what I've gathered through research, the SE 3 is electrically compatible with the iPhone 8 screens but the flex cables are slightly different lengths so it may not seat correctly in the device housing
Bu yanıt yardımcı oldu mu?
Update: While the iPhone 8 screen works with the SE 2020, and the SE 2020 screen works with the SE 2022, the iPhone 8 screen may or may not work in the SE 2022.
That's not true, I repaired my SE2022 with an old 8 LCD part.
It cant be used. I have used an iPhone 8 / SE 2020 LCD and it will not touch and the screen will not display correctly
iPhone 8 screens can be used on 2020 SE without a problem. However, the SE screen on an iPhone 8 will lose 3D Touch.
You can use a "copier box" to read the LCD info from the defective screen and write it into the replacement one to activate 3D and true tone.
Oh right, I never new that about 3D touch. I generally just buy iPhone 8 screens for both 8’s and SE’s as the 3D touch still works then. Thanks
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 4,658
