6 beep problem when I try to open.
Dell Inspiron 3542
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Dell Inspiron 3542
Bu iyi bir soru mu?
Hi,
A 6 beep error code is a video subsystem failure on the motherboard.
Here's a solution that might work, but maybe not, you can only try. If not you will need the schematics for the motherboard to find out what's happened or you have to replace the motherboard.
Here's the owner manual for the laptop, from this Dell support webpage for the laptop which may help as it shows how to access the motherboard etc.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 17
Her zaman: 437
