To start with, is the water on top of the display or under it? My guess is behind it from your description, but I just wanted to make sure.
You are most likely able to have the TV working as normal again. :D
If the water is on top of the screen, take a dry cloth and gently use it to get rid of the water.
If the water is behind the screen, please add a picture of it so that someone with more experience to be able to help you with a solution for how to solve that.
Adding images to an existing question
In the future, avoid using something wet like water or any other chemical/alcohol for cleaning a screen.
Most times, you are good just using a dry microfibre cloth to gently remove most of the dust etc. from the screen.
If there is something eg. sticky, it will probably don't be enough and you may use a slightly DAMP (water) cloth, or some dedicated screen cleaner (spray it on the cloth, NOT directly on the screen).
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
