Ana içeriğe geç
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
Alienware M15 R3 Fan buzzing. on and off
When I turn on my laptop already both my fans are really loud and I just assume thats because it needs a cleaning but my right fan recently has been buzzing incredibly loudly and once I removed the bottom cover I saw that it was turning on for around 5 seconds then turns off for around 10 seconds and it keeps doing it until my laptop turns off.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
I'll just clarify things up here:
The device is an Alienware M15 R2 (I know Kam IRL so he's showed me it on pictures)
The fans are "Buzzing" and are constantly on and off
The Hinge is toast (Broken - it would appear a screw came loose as he showed me this before)
The screen is basically free from it's hinge and is broken internally (the hinge)
I have directed him to this forum for some advice so if you all can please help him both him and I would appreciate it.
Kind regards,
Nick P
tarafından
@jayeff can you offer any advice? I am going to do a repair assessment tomorrow morning with my toolkit. He (@roberto1) says that one tiny phillips screw has come out alongside the complete loss of structural rigidity for the screen.
Also he asked dell what a replacement screen would be and they quoted something ludicrous (Somewhere along the lines of 2k AUD)
Kind regards,
Nick P
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @np_f1_2021
Check if the hinges are still securely attached to the lid. I'm not sure where you meant that it is loose, Iid or base assembly, or if the hinges are literally broken.
If the base assembly side is loose, I would check if the posts that the hinges screw into on the base assembly are OK and not broken.
Here's the service manual for the laptop that may help.
If the posts are broken (and not the hinge per se) usually the part number for the base enclosure is to be found somewhere in the enclosure. The only problem with this is that you most probably will have to completely dis-assemble the laptop to find it.
If the problem is in the lid, it seems that the display panel is glued into the cover, so I can't see how the hinges are attached to the lid.
Maybe use a heat gun? to prise off the cover but if the screen still works OK maybe not, given the cost.
If the hinges are literally broken maybe work out how they're assembled and try to source replacements and somehow replace the broken part with parts from the new ones, i.e. if the centre pin of the hinge (or whatever is broken) is snapped but the section joining the lid is OK and secure then try to remove the pin and replace it with the bottom part of the new hinge etc. Not sure if this is practical but you will know better when you can see what's wrong.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks @jayeff for the quick reply. I am hopefully going to try and fix it over the weekend and will update you as i go
tarafından
Update: I got sick and this never actually materialised. I was poking around on ebay and came across a listing for this screen. I don't know if i should recommend this to my friend @roberto1. I'll link it here: https://www.ebay.com.au/itm/265476449660...
tarafından
Yorum Ekle
Yanıtını ekle
Kam F sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,019
