Ana içeriğe geç
The HP Pavilion 15.6” inch screen laptop with clear audio, a powerful 5th generation Intel Core processor and a sleek, stylish design. This laptop is exceptional for web browsing, word processing, and other simple programs. It is identified by the following model number: 15-ab165us.
My screen flickers and turns off when moved
The screen will turn off temporarily if you move the laptop or turn it certain ways. It seems to me that there is probably a short in one of the screen cables. I have never opened a laptop that was working afterwards, so any help available here for how to open it safely would be amazing, thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Hi @dougil,
What is the model number of the laptop as shown on the information label on the bottom of the laptop?
tarafından
Hi, thanks for such a quick reply! The model number is 15-dy2193dx
tarafından
@dougil
Having a problem with the model number.
Is there a "product number" on the info label at all?
tarafından
Let me get back to you in a while with that. I don't have the laptop in front of me, I had the model number written down. It will be a few hours, sorry for the delay
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @dougil
I couldn't find the maintenance and service guide for your exact model.
Found the page for a 15-dy2000 model which I thought might use the same service guide
Go to p.50 to view the necessary pre-requisite steps and then the procedure to remove the display assembly. This should allow you to check the display cable to see if it damaged or just loose (either end).
If the cable is damaged where it passes through the hinge to get from the motherboard to the display assembly, there is a parts list on p.19 (item #6). Search online using the appropriate to your model part number only to get results for suppliers of the part. Usually the part number is also printed on the cable if you wish to verify which one you need.
Hopefully the service guide is applicable to your model as the only thing that HP shows for it is the product specifications and nothing else unlike other models it has.
If none of the part numbers match up to what yours is, search for "HP Partsurfer" and when the page opens (it must be off at the moment as it is not working) insert the "product number" in the search term on the page, to hopefully find your model and all the parts and part numbers.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Ittends to be an issue with the display wiring either being loose or damaged, but sometimes the inverter and/or the backlight can cause the problem.
Here is a link to a Youtube video where someone goes through the process of disassembling the Pavilion and replaces the lcd display wiring.
https://www.youtube.com/watch?v=T6461THx...
Puan 0
Yorum Ekle
Yanıtını ekle
Douglas Illner sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 250
