Ana içeriğe geç
My laptop is acting funny.
I need help. My laptop sometimes acts weird like, I can't click anything but my mouse still working and able to move on screen. It usually happens when I'm switching tabs between software. my laptop sometimes also suddenly mouseclicking and scrollclick on itself. I've updated windows/GPU and drives but still happening. need help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
I also have the same issues. My laptop don't work at all for a while. But after that, it works well. What should I do to recover this issues?
tarafından
@larrymurray
If your having the same touchpad issues as the OP above, try the answer below to determine if it is the touchpad or something else.
tarafından
@jayeff Yeah, touchpad. I'm a little bit confused. Should I need to replace my laptop touchpad?
tarafından
@larrymurray
Did you try what was suggested in the Most Helpful Answer below?
If disabling the touchpad and using a USB mouse stopped the problem from happening, it looks like there is a problem with the touchpad.
tarafından
Yes, I figured it out later. My touchpad didn't work.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Disable the touchpad (Fn+F10) and use a USB mouse connected to the laptop to navigate and check if the problem is still there or not.
If it doesn't happen, it may be that the touchpad is intermittently faulty and producing "ghost touches".
Has the keyboard/touchpad gotten wet at all?
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
the same thing is still happening even after I disable touchpad, do you know any other reasons as to why this is happening?
tarafından
@Kenzie Retro
Try starting in safe mode and check if the problem still occurs.
tarafından
I am truly sorry, i've been trying to access safe mode but I don't think I can get the bitlock recovery key, which won't allow me into safe mode. Do you have any other alternative way to fix this? or should I just reset my laptop?
tarafından
@Kenzie Retro
Here's a link that may help/ Hopefully it applies to Asus as well.
To be safe maybe backup the drive to an external drive before you do anything else. That way your data is safe if it goes pear shaped.
tarafından
Yorum Ekle
Yanıtını ekle
Kenzie Retro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 451
