Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
Power Button or Button IC issue?
I have an iPhone 5 used for fun, not a daily driver. The power button only intermittently works. When it does work, it only works pressed in very specific ways. Is this more likely to be a power button issue or a board issue?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If I'm pondering a problem with any kind of machinery as to whether it's electronic or mechanical, I tend to look toward the mechanical parts first. Anything that moves is going to eventually wear out no matter how well designed. Electronics, on the other hand, just move electrons from one place to another, so with no moving parts, it's going to take a lot longer to wear out.
In your case, when you press the power button you're pressing a physical switch that moves and connects two electrical points. So at this point you're simply completing a circuit that makes a round trip to the circuit board via a flex cable. If the switch gets contaminated or the contacts wear then its operation can easily become intermittent as you describe.
So the good news is you can buy a new switch here at iFixit for only about $5 USD.
iPhone 5 Audio Control and Power Button Cable - iFixit Store
You can also get the part packaged with the tools you need to do the job for about $10 USD.
The bad news is that it's one of those pain-in-the-a$$ repairs that make you ponder long and hard whether it's worth it or not. You have to open up the case, take out the battery and motherboard and just generally take a whole bunch of stuff apart to get to that cable with the switch mounted on it. There is a guide for it, though, so that's something.
iPhone 5 Audio Control and Power Button Cable Replacement - iFixit Repair Guide
Good luck, let us know how it goes!
This cable connects the volume buttons, mute/silent button, power button, and vibrate/ring switch to the logic board. In addition, it holds the power contacts for the vibrator. Compatible with all iPhone 5 models. Görseli
Ürün
$14.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Idris Reimov sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 117
