Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
242 Soru Tümünü görüntüle
Replaced Logic board, worked for a couple months, battery now dead
I needed to replace my logic board as the original one had issues (https://developer.apple.com/forums/threa...) and was successful in doing so.
I used my MBP for a couple months post install and it worked great. Just recently, the battery life has been nonexistent and needs to be plugged in via USB-C or the laptop will shutdown.
coconutbattery reports:
  • Current Charge: 0 mAh
  • Full charge capacity: 208 mAh
  • Design capacity: 3.1%
  • Cycle count: 152
  • macOS Battery status: Poor
I double checked the contacts from the logic board to the battery controller and it looks ok to me. I can confirm that the battery isn't charging since I checked it with a multimeter and it showed around 2V.
My suspicion is that the problem is with the (new) logic board -- anyone else think so too?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Comments:
Can you post the CoconutBattery screen so we can get the rest of the info. Adding images to an existing question
I would stay given the age of your system you may just need a new battery.
tarafından
Question edited with image. I don't think the battery itself is of issue since it retained charge normally before I replaced the logic board. Maybe the battery controller?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You've got a double whammy! First the battery needs to be replaced, while the cycles are not beyond the 1k limit, the age is over the expected lifespan. MacBook Pro 15" Retina (Late 2016-2017) Battery and here's the guide to put it in MacBook Pro 15" Touch Bar Late 2016 Battery Replacement
But you also have a charging logic issue! This system will need the logic board repaired as well. You'll note the charger is plugged in but the charger is not charging Charging with 0 Watts Which it should be!
MacBook Pro 15" Retina (Late 2016-2017) Battery Görseli
Ürün
$119.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
aluminum robot sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 47
