How do I clear the Battery service warning after replacing the battery
I replaced my battery with the iFixit kit (MacBook Pro 15" Retina (Late 2016-2017) Battery) , and went through a couple of cycles of charge/discharge to reset the battery controller. I still get the message in the battery control panel "Your battery capacity is significantly reduced..."
Following advice found elsewhere, I also did a shift-control-option-power up to clear the System Management Contnroller
I still get the message. Everything seems to work fine, but I'd like to fix this so I know if there really is a problem
Bu iyi bir soru mu?
