pram battery will not stay in holder
battery will not stay in holder can it be secured any other way?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Hi
Aslong as the battery is making a good electrical connection you could use kapton tape or electrical tapes to help hold it down
If they don’t work you could try conductive silver epoxy but you would have a hard time replacing it again if you were to do that
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 114
5 Yorum
Can you add an image of the holder?
Duck tarafından
Sorry hit the wrong button will send a photo
felix cavaliere tarafından
having trouble with the photo
@paalitha try this. Just edit your QUESTION Adding images to an existing question
oldturkey03 tarafından
Are you using the correct battery? There is a thinner battery which looks like the same battery but its not! The size of the battery is 20mm diameter x 3.2mm thickness.
Make sure you have the correct battery using a caliper to measure (use some electrical tap on the top as you don't want to short it out.
You need the BR2032 battery there is also a CR2032 which is physically the same. BR2032 and CR2032 are not exactly interchangeable.
BR2032 has a very low discharge rate per year and can last up to 7 years.
However, I read that BR2032 maintains a constant voltage (3) for quite some time and the degrades rapidly when failing.
The CR2032 has a more gradual degradation in voltage over time.
The CR2032 may be more accommodating to colder temperatures than BR2032.
The circuit that these are designed for may differ due to the different expected characteristics of the battery.
Dan tarafından
