Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Soru Tümünü görüntüle
What screens are compatible
I have a 2015 MacBook Pro Retina 13” model A1502 that needs a new screen. There’s another MacBook Pro that’s a 2017 model number A1708. Are these interchangeable as long as they’re within the same generation or do I have an exact identical screen to replace the screen? Do processors, GHz speed etc. have to be the same?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sorry ☹️ A can of Peas is not the same as a can of Carrots!
The key is the model ID not the series designation. So let’s look at EveryMac’s listing for these systems:
You need what the MacBookPro12,1 ID systems use for parts, that’s your only option. Here’s the needed part MacBook Pro 13" Retina (Early 2015) Display Assembly and the guide to put it in MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement
Because of popularity of this system (many are still used) as well as the anti-reflective coatings often failing finding a Grade-A display is tough and even the lower grade displays are expensive.
MacBook Pro 13" Retina (Early 2015) Display Assembly Görseli
Ürün
$449.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
In addition to what Dan has already said. The 2015 model is a bit of an anomaly in my recollection. Its display is unique. Even though the displays from this timeframe look almost indistinguishable from one another. And the chassis of the MacBook Pros of this era also look very similar across several models.
But the 2015 stands alone.
Logic.wiki has a super extensive guide for MacBook screen compatibility across models that I have made use of on more than one occasion.
Puan 1
Yorum Ekle
Yanıtını ekle
Anthony DiPietro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 570
