Ana içeriğe geç
HP ProBook 650 G5 için onarım kılavuzları, kullanım ve servis kılavuzları. Bu teknoloji, birçok amaç için kullanılan bir bilgisayar teknolojisidir.
computer freezing after windows update
after water has spilled on it.....it could not boot to windows so i did a fresh installation of windows 11.It works well without windows update ....when you do windows update, certain drivers install well but when it comes to installing the display driver the computer freezes and displays a blank screen....it freezes until yu force shutdown.i did fresh installations severals times the issue still remains....out of options now please help
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @kellz
Appears that there is a hardware problem somewhere and it was most probably caused by the water spilling onto the laptop.
Did you open the laptop and check that all the water was removed from the laptop and that it was cleaned using Isopropyl Alcohol 99%+?
If not, I suggest that you attend to the water spill problem first before the laptop fails even further.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your laptop and then remove the battery as soon as possible from the laptop to minimize any further damage.
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is the maintenance and service guide for the laptop that will help to disassemble it correctly
If this process seems too daunting, take your laptop to a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
i left the computer with a kid playing games.....when the water spilled, the computer turned off and he did not know what to do so the battery stayed about 2 hours in the computer until i came back and removed it...dried the computer.....opened it and cleaned the motherboard using isopropyl alcohol.....then comes the problem
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Kelvin Sibanda sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 428
