Ana içeriğe geç
The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
Won’t switch on
Won’t turn on after dropped
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
is there any damage you can see on the outside? was it dropped from a high or low place? was it dropped on hardwood/tile/concrete or carpet? did you drop the headset or the controller? could you add some photos if theres any external damage please?
Adding images to an existing question
tarafından
Sorry for the late response. No visible damage won't turn on after charging just system showing flat battery in goggles then disappearing it was dropped onto carpet from my 9 year old daughters head
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This question is already covered in the "Meta quest ™" Manual.
If you search this up it says"
Dropping it, especially on a hard surface, can potentially cause damage to the headset and battery. Inspect your headset for visual damage before each use. If you suspect damage to your headset or battery, contact Oculus Support. "
The online manual is downloadable on the web.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
ianj117 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 203
