Switching on the bulb
My washroom's bulb always blinks several times before comes to proper working condition. So what is the reason behind this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@muhammedsa33137 take a look at this teardown LED Light Bulb Teardown It will show you how to get into one of those and this one LED Birne Lampe 230V E27 defekt reparieren will show you how to check and possibly repair the bulb. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Adding images to an existing question
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Kılavuz
Zorluk:
Orta
30 minutes
Kılavuz
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
It may be that the electronic components in the LED light are beginning to fail. Usually it is the capacitors in the light as they may fail prematurely due to the heat generated by the operation of the LED light.
It could also be that the light is loose in the light fitting, making for a poor electrical connection
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 528
3 Yorum
Hi @muhammedsa33137,
Please verify the type of bulb e.g. Incandescent, CFL (compact fluorescent), Fluorescent tube or LED.
jayeff tarafından
It is an LED bulb.
Muhammed Saad Islahi tarafından
My bulb is not working what i do?
Hassan tarafından
