Why is my GameCube turning off suddenly?
My GameCube turns off when I least expect it to. I didn't even touch the power button. What should I do about that.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@sethturner50892 just like @andrewsawesome already said, time to take it apart. Yor GameCube could be over 20 years old and things happen when age creeps up. Use these guides Nintendo GameCube to work on it. Clean the fan, check the capacitors and check the traces on all boards, for corrosion. That is pretty common after that long time. If unclear or if anything looks odd, you can always post some images with your Question Adding images to an existing question
If you are still using the original power supply, then check the output voltage on it. Wiggle the cable and see if that turns off the output. Of course, you will need a multimeter for that.
Bu yanıt yardımcı oldu mu?
Probably full of dust. A new clean should help.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 765
@sethturner50892 Have you checked that the power supply is good and there are no bulged, burnt or blown components?
Andrew S tarafından
