Ana içeriğe geç
Samsung tarafından Ağustos 2018'de piyasaya sürülen akıllı saat.
Watch not functioning after swimming
My watch haywire after swimming. Then there's like green screen on display, and the watch totally off. I can't restart it and all button not function. I can see some droplets at the sensor glass. Any idea what's the problem?
Update (08/07/23)
Resim
Resim
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @syahril
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the watch's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your watch and then remove the battery as soon as possible from the watch to minimize any further damage.
Then you need to dis-assemble the rest of the watch and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the watch might possibly work correctly again.
If your watch is a Galaxy Watch and not a different Galaxy watch e.g. Watch Active, Watch 2, Watch 3 etc, here's the ifixit Samsung Galaxy Watch that may help
If this process seems too daunting, take your watch to a reputable, professional phone or electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
Hi Jayeff. Thanks for feedback. I'll try clean it first. Btw, is there any probability damage to battery /motherboard / display which I'd to order it as spare first?
tarafından
@syahril
May be best to clean it first and then check if it works or not, you may be lucky.
Batteries don't swim very well so perhaps it may need replacing
tarafından
I opened it, clean it up. Then, try to charge it. Can see the watch is charging and screen show rebooting display then screen dead. I can see the motherboard is rusty already.
tarafından
@syahril
Try cleaning it a few more times. Allow it to fully dry between each clean and then allow a bit more time between each clean after it is dry to see if the corrosion starts up again. Sometimes it is very persistent.
Do not connect the battery after each clean as this may cause more damage if the corrosion is still there but not yet visible.
You've got it charging and booting which is better than before so you may have to be a bit patient when repairing it and not rush it.
tarafından
how do you get the back off
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Syahril sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 91
Her zaman: 13,623
