My Logitech M185 does not turn on
Hi, I just got a used Logitech M185 but it does not turn on.
I already opened it but I couldn't find anything suspicious.
Is there anything else I could try?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Hi @websnke
Are the battery connector terminals in the mouse, bright and shiny i.e. not corroded and are they exerting enough tension on the battery when it is inserted, ensuring a good electrical connection?
If so then you may have to open the mouse and check for any obvious problems on the motherboard e.g. loose solder joint on motherboard from the battery terminals or water damage to the board, burnt looking components etc.
Being a "used" device, unless you know its history, you don't know what may have happened to it.
Here's the ifixit Logitech M185 Wireless Mouse Disassembly guide that may help.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 56
Her zaman: 1,215
6 Yorum
Have you tried changing batteries?
Dany tarafından
Yes, I already tried that.
[deleted] tarafından
@websnke When you turn on the mouse then plug the USB receiver into your PC, is there a sound from your PC speaker?
Dany tarafından
@dannish
The main problem is that the mouse doesn't turn on at all. The USB receiver should be fine.
@websnke These sort of mice use an invisible optic system so you can't visually tell if the mice is running or not, they don't have the usual red laser of most mice. Hence the need for the sound to really check if the mouse is active and being detected.
Dany tarafından
1 tane daha yorum göster
