Ana içeriğe geç
Find repair and additional information for the GE Refrigerator GWE19JSL, a 2017 refrigerator-freezer model with automatic defrost functionality, lacking a through-the-door dispenser or ice maker. This page covers information for model numbers matching the pattern GWE19JSL****.
Why does my GE GWE19JYLGFFS fridge make this grinding noise?
This noise has been happening randomly for 5 months. I've had technicians out twice to fix, but when they arrived it stopped. I showed video footage of the issue and one guy said it was the 'yoder loop" and it would eventually stop. I think it's safe to say that's not going to happen at this point so any idea/suggestions you all may have on this I would appreciate.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @mrstraightface
Don't know the reason but suggest that you purchase the service manual for the refrigerator and run the diagnostic tests and check if you can make the noise happen when running a test to hopefully find out what may be causing it
I realize that the refrigerator model linked is not the same but the two models use the same service manual i.e. GE mini manual part # 31-1000534. Unfortunately, I couldn't find a free download online. Perhaps verify with the seller what the manual's part number is before purchasing
If you do find the problem and it is a faulty part, here's a parts list that is useful. Find the required part and then search online for the part number only to find suppliers that suit you best.
If you determine that the problem is related to a sealed system component i.e. compressor, condenser, evaporator unit, filter dryer associated piping etc, consult the warranty section of the user manual for the refrigerator as with some models there's a longer warranty period for sealed section components than for other parts in the refrigerator, so it still may be covered by the warranty.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
MrStraightface sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 206
