Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Fan not working even after replacing
Hi all (Dan),
I have a MacBook Pro 2015 13" which has a fan that won't run. I have...
Put a known good fan in
Replaced keyboard and trackpad cable
Replied thermal paste
New SSD
Fresh install
SMC and PRAM
I used 'mac fan controller' which worked, the fan was controllable up to full RPM and all of the RPMs in-between, but the Mac just won't control it. I assume a faulty LB?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@andyc7117 may be not a faulty logic board but a failed part in the fan circuitry. This could be related to an issue with either the Tach circuitry of the fan or the Fan Control circuitry. I would suggest that you start by checking the components and see what results you get.
Copy the image to your computer since there will be times where they may have to disappear ;-)
If nothing else, let's see your logic board. Maybe somebody on here can identify any issues with it. Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you. It's started working again after (another) fresh OS install.
tarafından
Yorum Ekle
Yanıtını ekle
Andy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 155
