Ana içeriğe geç
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
UMD laser does not turn on regardless of drive
The laser on the PSP 1000 doesn't turn on but its spins, the laser moves and tries to focus, I except its an issue on-board. I don't want to replace the board, instead try component level fix. I understand their are tons of components to check along with way but what is the most common point of failure for this specific issue.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@kickflipa180 there really aren't any common points for this, The most common issues were Firmware issues. Check the PSP forums for that.
After that, you can check your motherboard for any damaged, missing or charred looking component. Post some well focused and large enough images of your motherboard with the Question. That way we can see what you see and maybe identify an issue, Adding images to an existing question Pay particular attention to componets around CN9501 and IC9501 and 9502 and CN9503
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
After your mention of firmware being a common issue, I tried my best efforts to check if that is indeed the issue and IT WAS! Thanks for setting me on the right path friend :)
tarafından
How ? What did you do ?
tarafından
Hey KickFlipa180 3-343 did you find your fix?? Having the same problem would appreciate ANY help!!
tarafından
Yorum Ekle
Yanıtını ekle
KickFlipa180 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 34
Her zaman: 668
