Potential Charging Port Problem (Really Odd Situation)
I would appreciate some thoughts and ideally suggestions on an issue with my Switch.
So the situation is this, a few years ago I purchased an Oivo Grip Controller, as a substitute for the standard JoyCons. Over time, the charge port became loose, causing charging interruptions. I attempted to reposition the cable, but now the controller has stopped working properly (it no longer responds or pairs correctly with the Nintendo Switch).
I tried reconnecting the charger and even bought a new controller, but it only works when plugged in. I suspect an issue with the Switch's charging port. I'm seeking advice on potential damage and considering taking it apart for repairs. Resolving this is crucial for me as playing the Switch helps with my depression. Any assistance or suggestions would be greatly appreciated.
-Edit: To include pictures of (Oivo Controller front view and charge port, Nexigo controller, Switch Console side rails and charge port.) respectively for reference.
-Edit 2:Got rid of info about rail connectors since after contacting the company, it seems that they have nothing to do with the connection of the controller, it's strictly for stability of the mounted console.
-Update: I found a pair of actual JoyCons today and tested them out and they work perfectly fine, which let's me know it's not a problem with the actual Switchs side rails, as far as I can tell anyway. (Pictures included for reference.)
-Original Oivo Controller Grip:
-Oivo Charge Port:
-Replacement NexiGo GripCon:
-Switch Side Rail (Right):
-Switch Side Rail (Left):
-Switch Charge Port:
Bu iyi bir soru mu?
Hey there @jakiecakes, I edited your question a bit for readability's sake, and attempted to keep the important information. Could we see some photos of the sides of your Nintendo Switch? This will help us in determining if the sensor rails are damaged Adding images to an existing question
Jacob Mehnert tarafından
@jmehnert I liked the old version better. Had more character and had everything that the OP wanted us to know. I understand it was a bit more cumbersome to read but did eventually get its point across. Just saying ;)
oldturkey03 tarafından
Aye good looking fellow Jacob, I do have an issue with overloading with information as I believe any detail could be important to the situation, but this isn't always the case and I'm also not good at condensing, so thank you~
Jakiecakes tarafından
@oldturkey03 Thank you as well, I appreciate the appreciation haha but I'm sure most people would be overwhelmed by my potential rambling lol
@jakiecakes charging port isnt an easy repair for just anyone on a switch as the charge port has 2 rows of pins, it requires a soldering iron and hot air station, also if any of the solder pads under the port has been ripped then it would require jumper wires to replace the pads
daniel tarafından
20 tane daha yorum göster
