Ana içeriğe geç
The Samsung Galaxy A53 5G Is a Mid-Tier phone released by Samsung on March 17, 2021
Phone suddenly stopped turning on. Any Advice?
So today my phone stopped powering on, it only draws 5V at 0.21A, from what it sounds like the motherboard is bad, however is it possible that it could be the battery? If this is a mainboard problem, what could cause this? If anyone could maybe point me in the right direction, that would be great.
Update: I am 99% certain it is a motherboard problem at this point. If anyone knows what I should check first or any advice at all please comment below.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @bh_j39200
Has the phone been dropped or gotten wet just prior to this happening?
Here's the SM A536B Troubleshooting section from the service manual that may help.
Go to p.22 (of 92) onwards to view the procedures to check for a No Power situation
Update (01/21/24)
@bh_j39200
No easy way at board level unless it is a visibly obvious damaged component. You just have to follow the checks.
Start at p.24. It's listed in order what components to check.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
No it wasn't dropped, and I keep it away from liquids. It just stopped powering on. Only draws about 5V 0.21A off a 20W Charger, I have tried hard resets, etc. I am positive it is a hardware problem, but I am trying to figure out what.
tarafından
@bh_j39200
Click on the link inserted in my answer and go to the page I suggested. It shows what to check
tarafından
Checked the battery and its at 4.0V, power button is at the correct voltage. This seems to be a motherboard problem. Do you know what component on the motherboard could cause a no power issue? Or is there a easy way to find out?
tarafından
Yorum Ekle
Yanıtını ekle
Jonathan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 260
