only using 2gb ram from 4gb ram
my laptop has 4gb ram (probably 2+2gb) but one day one of the ram became unusable and still is not usable. thanks in advance for helping me.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
The answer to this is very simple: open up your laptop and replace the RAM. 4GB is not very usable today, and your system supports a maximum of 8GB, so while you are replacing the RAM, it's a good idea to do a simple upgrade. Look at page 5 of this manual. It will tell you how to take out your current RAM and replace it. A good replacement/upgrade I have used for computers before is Crucial 2x4B DDR3 Laptop Memory. I have used it before in multiple laptops, and highly recommend it.
Follow these instructions, and you should have 8GB of working RAM, maxing out your system for around $30!
EDIT: Do not throw away either of the old RAM cards, keep them as a backup in case you need them. Spare parts can come in handy later.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 86
Hi @yunij41,
have you tried finding out which ram module is faulty by buying a replacement ram module to see when both work OK?
What have you tried
jayeff tarafından
