Ana içeriğe geç
Les touch blan dans ecran
I need to fix white spots in ecran
Update (01/26/24)
How to fix this problem ?1
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@h4ck95200 post a picture of what this looks like. That way we can see what you see and provide you with a helpful answer. Adding images to an existing question
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @h4ck95200
Try starting the laptop in safe mode and check if the display is OK. This is just to eliminate the possibility that it may be a video driver problem that is the cause of the problem
It the problem is still there in safe mode connect an external monitor (TV?) to the laptop's HDMI port and check if the display from the laptop is OK when viewed on the monitor. Don't forget to press the display action key (top row on keyboard) to switch the display between the laptop screen only, the external monitor only or both on together.
If the display on the external monitor is OK then there's a problem either with the video cable/cable connection between the motherboard and the LCD panel or more likely with the LCD panel in the laptop.
Here's the maintenance and service guide, taken from this support webpage for the model.
Go to p.65 to view the procedure to remove the display assembly. This will also allow you to check if the video cable connection on the motherboard (see p.47 #4) is OK
If you determine that the LCD panel needs replacing there are 4 different panels used in the model. Go to p.22→p.23 Item #3 to find the HP part numbers for the LCD panel. Usually the part number is on the back of the LCD panel if you wish to verify which one is used in your laptop.
Search online for the applicable to your model variant part number only to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
H4ck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 329
