Ana içeriğe geç
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
20 Soru Tümünü görüntüle
Remove Existing Joystick Solder
I am trying to replace the joystick due to it sticking/stick drift; however, I cannot remove the existing solder. Does anyone have any tips or am I doing it wrong? I also believe I've burnt the circuit board but luckily this is a practice one.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @jayshiz
I would apply flux to the solder joints and use low melt solder to mix with the existing (probably lead free) solder. It will make it easier to reflow them with a heat gun or a soldering iron.
Once you managed to get it out, clean the holes with solder wick and you'll have no problem installing the new stick.
Hope it helps!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
sorry, your initial comment was incredibly helpful, but could you explain more how using a heat gun will reflow, I have a very basic understanding of soldering, but I'm still learning, and there's no tutorials online explaining this. Thanks!
tarafından
I am in the process of making a guide how to do it. I will link it here so you can follow it along.
tarafından
Yorum Ekle
Yanıtını ekle
Jay Shiz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 128
Her zaman: 1,646
