Ana içeriğe geç
DJI Mini 2, DJI tarafından 2020 yılında üretilmiş küçük bir drona verilen addır. DJI Mini 2, 4K/30fps video ve 10 km 720p/30fps video aktarımı özelliklerine sahiptir.
incompatible gimbal data error
powers on connects to drone, camera rotates left,right, up and down can view through camera. gimbal does not respond to wheel on controler. has incompatible gimbal data on display. will not take off. is i a board problem or a cable
Bu iyi bir soru mu?
Puan 1
1 Yorum
did you solve this problem?
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Let's do a little logical thinking here.
If the gimbal does its power on movement then the gimbal and cable to it from its controller in the AC are functional.
If you can view the camera, then the camera system and communication from the AC is functional.
The AC sees the gimbal and is getting data but does not like what it sees, so you are getting an "incompatible gimbal data" message.
Therefore, any commands to it from your Controller are ignored (or maybe the Controller isn't even sending the commands because of the error).
If that message appeared after your "minor" crash, then I would first suspect a dislodged cable in the AC.
But after that, a damaged PCB is a possibility.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I'm afraid the reader does not know about an AC being Altitude Controller, nor where to locate this in the drone...
tarafından Paylaş
AC is a common abbreviation for AirCraft
tarafından Paylaş
gps board ended up being culprit,bought new still didnt work, took board from another broken drone and all well now.
tarafından Paylaş
Yorum Ekle
You will need to replace the gimbal. The best website to buy parts from is: djioemparts.com.
You can buy a new gimbal here for $80 USD https://djioemparts.com/collections/dji-...
Best of luck, BetaTech Labs Repair AU
Puan 1
2 Yorum:
the gimbal responds to startup/power on and does up down left right chk ok and i can view through camera, does not respond to up/down knob on controler so would that be gimbal or motherboard
tarafından Paylaş
did it beep at startup?
tarafından Paylaş
Yorum Ekle
Hi, Have you done any repairs recently? have you crashed recently?
Puan 0
4 Yorum:
very minor fall from about 8' into grass
tarafından Paylaş
Yeah, it looks like you messed up your gimbal
tarafından Paylaş
posting new answer...
tarafından Paylaş
finally was able to find solution, i replaced gps board and all is once again fine!
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
colderp sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 29
Son 30 gün: 92
Her zaman: 2,875
