Ana içeriğe geç
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
20 Soru Tümünü görüntüle
R shoulder button acting strange
I recently gave my 2ds xl to a technician to fix it because of this issue, and it does work now but not always, sometimes I click the R button and it works but most of the time it doesn't, why does this happen? and can someone tell me how to fix it? I saw someone on Youtube changing the motherboard to fix the R button but I don't want to do that, is there a different way to fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It sometimes works? That's a good sign, it's probably just dirty inside.
Start by taking the bottom case off so you can access the actual buttons. Then dip a q-tip in isopropyl alcohol (90% or higher), hold the ds so the hinge faces up, and use the wet qtip to press the R button a bunch of times. The goal is to get alcohol down inside the button, so a dripping qtip is probably best
I haven't had a reason to do this on a 2ds yet, but it's worked for me with ds lites. Normally I'd go with no fewer than ~30 presses, but you can just pop the battery back in and test it without reassembling everything
If that doesn't work, the button probably needs to be replaced.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I only have 70% isopropyl alcohol, would it be safe to use it?
tarafından
@nors84229 I have used it in the past, but i wouldn't reccomend it. Check your local dollar store, i know mine has 99% IPA.
tarafından
Yorum Ekle
Yanıtını ekle
نورس sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 74
