Battery STILL not charging.
Hi guys, so my battery said health was bad and wouldn’t charge… so I bought an I fix it one and replaced it. The charger light came on for a split decent now won’t charge the new battery despite working from power source..getting a new charger today to double check but what could be wrong now?
Bu iyi bir soru mu?
This pic was taken just now. It’s been unplugged all night
Nicky tarafından
@nikbe - How warm is it where you live? Find a cooler place to charge your system to be sure. If it doesn’t change then the battery sensor is defective.
Dan tarafından
It’s been warmer than usual I’m in south east England. 23c currently.
Ok I’ll try that. Thank you.
Nicky tarafından
So I’ve tried a new charger. Still not charging the new battery.. so I’m guessing it’s not the battery or the charger that is the problem here.
Nicky tarafından
@nikbe - What’s the batts temp now? Did charging in a cooler location change the temp as well as just sitting for a good hour in sleep.
It does look like the charging logic needs repairs. This will require good micro soldering skills and access to the needed parts. It maybe best to find a good Mac repair person who can fix your system.
Dan tarafından
2 tane daha yorum göster
