Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Battery STILL not charging.
Hi guys, so my battery said health was bad and wouldn’t charge… so I bought an I fix it one and replaced it. The charger light came on for a split decent now won’t charge the new battery despite working from power source..getting a new charger today to double check but what could be wrong now?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
7 Yorum:
This pic was taken just now. It’s been unplugged all night
tarafından
@nikbe - How warm is it where you live? Find a cooler place to charge your system to be sure. If it doesn’t change then the battery sensor is defective.
tarafından
It’s been warmer than usual I’m in south east England. 23c currently.
Ok I’ll try that. Thank you.
tarafından
So I’ve tried a new charger. Still not charging the new battery.. so I’m guessing it’s not the battery or the charger that is the problem here.
tarafından
@nikbe - What’s the batts temp now? Did charging in a cooler location change the temp as well as just sitting for a good hour in sleep.
It does look like the charging logic needs repairs. This will require good micro soldering skills and access to the needed parts. It maybe best to find a good Mac repair person who can fix your system.
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Well your battery is overheating! Presently over 80 degrees Fahrenheit. Is the system near sunny window?
So if the system is not being exposed to heat, then the battery may be bad or the charging logic has issues.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
This is the brand new battery from ifixit.
tarafından
No, not near sun. I’ve just turned on the laptop and temperature is saying 27.4c. can it be over heating if it’s been off?
tarafından
@nikbe - There is a thermal sensor within the battery, while you have the system turned off, the battery is still charging, only if you unplug it for a few hours to stabilize the temperature, then plug the system in and quickly take a fresh CoconutBattery snapshot is the temp still above 80 F/28 C? If it is then the battery is defective, still leaving the MagSafe plugged in does the charge rate (Charging with) now charging? It may take a few minutes for SMC to startup. If it’s not, the charging logic within the system needs repair.
tarafından
Yea it’s been unplugged all night and looking now it’s at 25.4c
tarafından
I’m going to get a new charger now just to be sure. But sounds like I have other issues like you say. Thank you for the advice
tarafından
Yorum Ekle
Yanıtını ekle
Nicky sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 55
