Ana içeriğe geç
İndüksiyon, dolaylı radyasyon, konveksiyon veya termal iletim yerine, metal tencerenin manyetik özelliklerini kullanarak manyetik alanı titreştirir ve bu sayede yiyeceklerinizi pişirmek için dirençli ısıtma sağlar.
Chip out of cooktop
How can I repair a small chip broken of the smog induction cooktop?
It happened when a knife was dropped hitting the side.
Only small but noticeable
Thanks
Bu iyi bir soru mu?
Puan 0
5 Yorum
Is the damage along the edge or near the coil areas? Can you post a few pics so we can see the damage clearly.
tarafından
The chip is along the edge, l will try and send some photos
tarafından
Sorry don’t know how to send photos 😔
tarafından
@johnwagenaar We get that question a lot, so here's a page showing you how to add images to your question.
Mevcut bir soruya görsel ekleme
tarafından
Thanks for the information, Jerry
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you have the chip and it fits cleanly in the space you could try a good cyanoacrylate glue like Loctite 1364076 Super Glue Easy Squeeze Gel. But it can’t be near the heated area as over time it will degrade.
If the chip is on the surface and/or you don’t have the loose piece you could use a black epoxy filler. First taping down the area to protect the rest of the area and limit creep of the area being filled. Keep in mind you may end up with a bump or still have a divot where the hole is. Using a knife to trim it may put the fill out and you don’t want to sand as the glass surface will then get scratched.
The bottom line it might be just better to accept the damage than trying to fix it.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks Dan, l do not have the chip, l better leave it and avoid looking at it.
Thanks for your advice
tarafından
Yorum Ekle
Yanıtını ekle
John Wagenaar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 67
Her zaman: 1,137
