Ana içeriğe geç
Repair and disassembly guides for Garmin GPS devices.
Garmin Oregon 600 GPS power switch replacement
Power switch ceased working, needs replacement
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @johns23099
Use an DMM (digital multimeter) to check that it is actually the power switch that is not working and not that it is a problem with a worn/broken rubber power button actuator (supplier examples)
Here's a teardown video that should help you to access the switch to check what the problem is i.e. switch or actuator button
Not sure as I can't see it too well in the video whether the power switch is an electrical switch on the motherboard or a tactile button on a flex cable connected to motherboard that is operated by the rubber button,
If it is the switch, post an image of the board (or flex cable) showing the switch. Here's how to do this on ifixit Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
JohnS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 43
