Trigger assembly issue . Not fixing
Ribbon between rubber strip and plastic tool got removed mistakenly while opening controller
Bu iyi bir soru mu?
Bu iyi bir soru mu?
iFixit does have a guide for replacing the trigger buttons, along with a guide for removing the wiring for the buttons. If the ribbon cable for the trigger button was damaged/severed, then it will need to be replaced.
Kılavuz
Zorluk:
Orta
15 - 45 minutes
Kılavuz
Zorluk:
Orta
30 - 45 minutes
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 62
5 Yorum
Hey there, can you elaborate on the issue that you are having with your controller? Also some pictures could help us better give you advice. Adding images to an existing question
Jacob Mehnert tarafından
can you send a picture?
Grant tarafından
When I was opening my PS3 controller, mistakenly the left side trigger along with rubber strip and plastic tool beneath ribbon got removed. I am not able to attach them
Divyarth Singh tarafından
Unable to send pics due to complicated process. Can you send a video or online video guidance if possible
@divyarthsingh im sure there are plenty of you tube videos on how to disassemble a PS controller you can find. but without pictures of your device we wont be able to help you really.
Logixal tarafından
