Hi @edmund7394
Try connecting an external monitor (TV?) to the laptop's HDMI port and check if its display stays stable. Press the F4 key to toggle between laptop screen only, both on together, extended view or external screen only.
If the display on the external monitor is also flickering then there's a problem on the motherboard that would have to be further investigated.
What is the full model number and product number of the laptop as shown on the product information label on the bottom of the laptop?
Asking as there are several variants of the HP ENVY x360 15-cn0??? series and some have two GPUs i.e. a discrete GPU (NVIDIA N17S-LG GeForce MX150) and an Intel UHD 620 integrated GPU, whilst others have the Intel UHD 620 integrated GPU only. So it might be the GPU if it is a discrete one. If your particular model has the two GPUs try using the Intel GPU and see if the display is stable.
If the external monitor display is OK, then try moving the laptop lid slowly, stress very slowly, back and forth to see if doing this affects the stability of the picture.
If it does then it may be a loose or damaged video cable.
If it doesn't then most likely it is a faulty LCD panel.
Here's the maintenance and service guide taken from this support webpage for the model series.
Go to p.52 to view the procedure to remove the display assembly. This will allow you to inspect the cable/cable connection and to replace the display.
The HP part numbers for all the display assemblies compatible with the laptop are shown at the top of p.52. Search online for the part number, applicable to your particular model variant to find suppliers that suit you best.
It looks like the video cable is part of the display assembly and that it is not available as a separate part.
Hi @edmund7394
Here's the HP ENVY x360 15-cn0950nz maintenance and service guide taken from this support page.
If the tests determine that it is the display panel that is the problem, the HP part numbers are shown on the top of p.51
Note: there are no discrete GPUs on any of the systemboards used in the model range only the integrated Intel GPU..
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
