Ana içeriğe geç
Intel i5-13450HX, RTX 3050 6GB, 8GB DDR5, 512GB SSD, Windows 11, 60Wh pil ve 170W adaptör özelliklerine sahip 15,6 inç FHD 144Hz dizüstü bilgisayar.
How do I clean the fans?
My LOQ 15IRX9 fans haven't been cleaned since it was bought, and I can see some dust building up on its bottom cover. I want to know how I can clean the fans on the inside by myself. How do I do it properly?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kialzi
Here's the hardware maintenance manual for the laptop.
Go to p.42 in the manual (48 of 68 pdf) to view the procedure to remove/replace the thermal module.
Once it's removed this will allow you gently clean the fans away from the other components inside the laptop.
Also once it has been removed, check the condition of the thermal paste on both the CPU and the GPU to make sure that it hasn't dried out and needs to be refreshed.
Here's the ifixit Termal Macun Nasıl Uygulanır guide that may help with this.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Open the laptop up(just unscrew everything on the back and use a small pick (can be a guitar pick) to open it and then just vacuum the dust out
You can also put a new SSD in (2242 or 2280)
Puan 0
Yorum Ekle
Yanıtını ekle
Kialzi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 21
Son 30 gün: 170
Her zaman: 2,204
