Ana içeriğe geç
LG'nin yenilikçi 4 Yollu karıştırıcısı, TurboDrum teknolojisiyle birleşerek giysilerinize zarar vermeden derinlemesine temizlik için yıkama performansınızı en üst düzeye çıkarır.
Machine stops a 2 times per cycle
Washer stops 2-3 times, all the cycle lights and the warm water flash. If I click the start button twice the machine unlocks and locks and then keeps going. I have already checked the water valves for blockage and used the smart LG diagnostic- nothing is “wrong”.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @jonthn93783
Go to p.30 in the service manual and run the machine in service mode and check if that shows if anything is wrong.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
The problem has persisted…I have tired to ohm out the water inlet valves (all seem to be fine), the LG app produced an IE error when I conducted the sound test, but verified no kink in water hose or lack of water pressure. The cycle only runs for about 5 minutes…usually after the initial tub is filled with water. Any ideas? I’m not sure a technician can troubleshoot further without replacing random parts?
tarafından Paylaş
@jonthn93783
Just verifying that no errors were shown when running the washing machine in service mode as described in the service manual?
tarafından Paylaş
Yorum Ekle
An unbalanced load will give an error and only happens during the spin cycle if it can't rebalance by filling with water. A faulty door switch or loose connector to it, might be causing this.
Puan 0
Yorum Ekle
Yanıtını ekle
JonThN sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 237
