Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
Phone not working at all
After fixing my iphone 4 screen my brother asked me to do his 3gs screen. It didn't turn on or respond to being plugged in to my pc. (It didn't come up on pc either). I changed the screen, all went well but it still wont turn on etc. I've left it on charge for a while but still nothing.
Any simple checks I can try??
Many Thanks in advance
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sam Short, start off by doing a hard reset " Press the two physical buttons sleep/wake and the home button on the iPhone, holding them for approximately 10-20 seconds.
After holding both buttons for approximately 5 seconds, the slide to power off button appears. Ignore this and continue to hold the buttons for a few more seconds, the screen will then go blank.
Continue to hold until the apple logo appears. This may take longer on older devices (up to 30 seconds).
The iPhone hard reset will now take place." from here.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Just noticed your comment. If your phone has not been recognized, start with your dock connector. Make sure that the pins are not bend, broken or corroded. Check for debris in the connector. Use a known good cable. The dock connector can be changed individually, use this guide to see how to do it. iPhone 3GS Dock Connector Replacement
tarafından
Yorum Ekle
En Yararlı Yanıt
within the Iphone are VERY SMALL RIBBONS. from my experience. Customers that try and work on the iphone / ipod. 70% cut the hidden ribbons by accident. While opening the case di you slip or press to hard and crack the mainboard?
other solutions:
a) Check the video cable
b) Check for lose connection by re-installing the screen.
c) Plug it into a pc. If the pc / mac recognizes it as a device.
Puan 4
1 Yorum:
I'm sure i didn't break anything. Problem is, it didn't work before i changed the screen. It was never recognized as a device when plugged in. My Bro said once the screen broke it worked for a while but then he just left it in a draw.
tarafından
Yorum Ekle
Yanıtını ekle
Sam Short sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 3,925
