Ana içeriğe geç
Acer AL2216W Capacitor Replacement
Nick
Nick ve 5 diğer katkıda bulunanlar
En son April 26, 2025 tarihinde güncellendi
2 saat
Zor
Topluluk-Katkılı Kılavuz
If your AL2216W is having problems, it is likely due to bad capacitors. Here are some common symptoms of bad capacitors:
Note: While some issues may be corrected with a partial repair, this is NOT RECOMMENDED. One bad capacitor usually means the rest will fail!
  • Power issues (Present issue)
  • Excessive transformer/inverter hum (Present)
  • Backlight problems
  • Auto adjust problems (VGA) (Present)
  • Random power issues are only resolved through a full power cycle (unplugging the monitor)
  • Video issues (Ex: Unstable image, video instability)
Original capacitor values (For Delta 00A power supply)
NOTE: I based the capacitor list on my monitor's specific power supply (Delta 00A). UNLESS YOU HAVE THE SAME PART IN YOUR MONITOR, YOU MUST VERIFY WHAT YOURS NEEDS TO AVOID COMPATIBILITY ISSUES BY TAKING THE MONITOR APART TO IDENTIFY WHAT CAPACITORS ARE USED. However, in many cases, the stock part is likely NLA or hard to find a matching replacement, especially as these monitors age. As such, you will likely need to use different capacitors that either have a higher voltage or uF rating and swap all of the original capacitors that remain that match the old part, even if they work, as doing this will likely cause the remaining original capacitors to fail sooner.
IMPORTANT: When swapping capacitors, stay as close to the original as possible. It’s okay to install a 35V 1000μF part instead of a 25V 1000μF part (or a 25V 2000μF replacement), but grossly exceeding the value of the stock part does not offer any benefits.
Part availability caution: While I have done my best throughout this guide's life (and still do what I can) to keep up with part phaseouts (and replacing hard "obsolete in practice" value components) by mitigating the issue as needed with components of a similar voltage or uF rating, I cannot continuously monitor the market. You may need to make additional substitutions!
  • 25V 1000uF (x2)
  • 10V 1000uF (x1)
  • 25V 220uF (x2)
  • 16V 2200uF (x1, Only found on early power supplies, and is used to drive the inverter transformer. This was not used in later power supply revisions as it was removed at some point.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Bu adımda kullanılan alet:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Current EET owners: All steps are noted if additional bits are needed, or if the EET will work without extra parts. This kit is no longer recommended due to add-on cost creep, but it still (mostly) works as-is without add-ons. The exception is Step 8 when a 5mm nut driver your kit doesn't include but is required.
    • Author's note: Due to cost creep issues with the 5mm nut driver ($10) and 5mm driver ($15), the EET has been removed. If you do not have the right toolkit, purchase the Pro Tech Go (or the refurbished full-sized Pro Tech, search for "refurbished"). If you are on a tight budget and want a cheap kit with lots and lots of bits, the Harbor Freight toolkit is a good alternative I have personally tested.
    • Backup source for 63/37 leaded solder: https://www.digikey.com/en/products/deta...
  2. Acer AL2216W Capacitor Replacement, Discharge the old capacitors: adım 2, 1 resimden 1.
    • CAUTION: If you are uncertain about handing high voltage parts, follow all provided warnings! A capacitor discharge tool is STRONGLY RECOMMENDED.
    • The filter capacitor will hold the most residual charge. Use caution around this capacitor!
    • Unplug the monitor for 24-48 hours. Wait 5-7 days before swapping the filter capacitor.
  3. Acer AL2216W Capacitor Replacement, Remove the stand: adım 3, 2 resimden 1. Acer AL2216W Capacitor Replacement, Remove the stand: adım 3, 2 resimden 2.
    • EET owners: Your kit has this bit. No purchase needed.
    • This monitor never came with a hinge cap. If yours has one, unclup the marks in black.
    • Remove the 4 screws from the monitor stand with a Philips #1 screwdriver. Remove the bottom screws first.
  4. Acer AL2216W Capacitor Replacement, Remove the back of the monitor: adım 4, 2 resimden 1. Acer AL2216W Capacitor Replacement, Remove the back of the monitor: adım 4, 2 resimden 2.
    • Sort this screw separately, as it is unique.
    • Remove 4 fine threaded screws from the back of the monitor with a Phillips #0 screwdriver. All of these screws are the same.
    My monitor, an Acer 2216W verion BL from 2007, has no screws other than the monitor stand screws. The back bezel is solidly glued down. No luck removing it so far :(
    Daniel Schwarz - Yanıt
    The back on this version is held together by snaps along the edge. I was able to get it off by putting a knife in the gap and hammering down onto the knife with a screwdriver handle. However, the circuitboard is completely different.
    Evan Richards -
  5. Acer AL2216W Capacitor Replacement, Unlatch the clips (Bottom): adım 5, 2 resimden 1. Acer AL2216W Capacitor Replacement, Unlatch the clips (Bottom): adım 5, 2 resimden 2.
    Jimmy
    $7.95
    • If the monitor has never been serviced, you may have to use a flathead screwdriver, Jimmy or a Heavy duty spudger. This will damage the plastic somewhat and is unavoidable. In some cases, you may be able to use a plastic pry tool instead of metal to avoid the damage, but not every time.
    • Open the monitor at the bottom of the monitor by releasing the four tabs with a flathead screwdriver or a Jimmy and plastic pry tool. If force is needed, the best way to do this is to put electrical tape on a flathead screwdriver and split the panels.
  6. Acer AL2216W Capacitor Replacement, Unlatch the clips (Side): adım 6, 1 resimden 1.
    • If you are having trouble doing this, use a pry tool. An unserviced monitor may not come up as easily.
    • With the monitor unclipped on the bottom, pull the sides of the monitor up. Do this slowly to avoid cracking the LCD.
  7. Acer AL2216W Capacitor Replacement, Remove the IEC socket screws: adım 7, 1 resimden 1.
    • After these screws are removed, the power supply will be exposed.
    • With the back of the monitor off, remove the 2 screws on the IEC power connector using a Phillips #0 screwdriver.
  8. Acer AL2216W Capacitor Replacement, Remove the video connection screws: adım 8, 1 resimden 1.
    • EET owners: Your bit does not have this kit. Step 1 covers what the current recommendation is (Pro Tech Go or HF toolkit).
    • Needlenose plyers can be used if you do not have a nut driver. However, it will be hard to properly re-tighten the screws.
    • Remove the 4 screw pins for the video cables from the monitor. Use a 5mm Nut bit/driver to remove the screw pins from the power supply shield.
  9. Acer AL2216W Capacitor Replacement, Disconnect the backlight cables: adım 9, 2 resimden 1. Acer AL2216W Capacitor Replacement, Disconnect the backlight cables: adım 9, 2 resimden 2.
    • Disconnect the CCFL cables from the power supply board.
    Our cables were in different order: from left to right: Blue, Blue, pink, pink
    Christof Dallermassl - Yanıt
    I suspect that’s either because you’re in a 240V country (I seen you used the pound symbol for the currency you use) or it’s a different part then the US ones. Mine had a 120-240V 00A Delta unit.
    You have a different revision or revised power supply. I used a bd monitor for the guide with the 00A power supply and inverter filter capacitor.
    Nick -
  10. Acer AL2216W Capacitor Replacement, Disconnect the button board: adım 10, 2 resimden 1. Acer AL2216W Capacitor Replacement, Disconnect the button board: adım 10, 2 resimden 2.
    • Board removal is optional.
    • Disconnect the flat flex cable that goes to the control board.
  11. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 1): adım 11, 2 resimden 1. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 1): adım 11, 2 resimden 2.
    • Remove the 2 lower screws that hold the power supply shield to the monitor with a Phillips #0 screwdriver.
  12. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): adım 12, 3 resimden 1. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): adım 12, 3 resimden 2. Acer AL2216W Capacitor Replacement, Remove the power supply shield (Part 2): adım 12, 3 resimden 3.
    • The lower shield does not have to be removed. However, it will make disassembly easier.
    • On the right side of the monitor, remove the remaining Phillips #0 screws holding the board shield in place.
    • Lift the lower plate up while removing the power supply shield to remove it from the monitor. Once this is done, you will have access to the power supply.
    • Removing the lower shield (Optional): To remove the lower shield, release the black tabs holding it in place, and lift up. Do this for all the tabs holding it in place.
  13. Acer AL2216W Capacitor Replacement, Remove the power supply: adım 13, 3 resimden 1. Acer AL2216W Capacitor Replacement, Remove the power supply: adım 13, 3 resimden 2. Acer AL2216W Capacitor Replacement, Remove the power supply: adım 13, 3 resimden 3.
    • IF YOU ARE REPLACING THE FILTER CAPACITOR, IT MUST BE DISCHARGED BEFORE REMOVAL FOR SAFETY!
    • The black screw is a ground screw and must be placed in the same location when reassembling the monitor. The remaining 3 screws can be installed in any order when reinstalling the power supply.
    • Any bulged capacitors are likely to have a residual charge, and the power supply should be handed with this assumption in mind if you see any visibly bulged capacitors.
    • With the power supply shield removed from the monitor, identify the power supply. Take note of the printed values, including the inverter cap (if present).
    • Remove the 4 Phillips #1 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis. Do not lift too much or the connector may be damaged!
    • This capacitor is only found on older power supplies. Replacement is optional, but recommended.
  14. Acer AL2216W Capacitor Replacement, (Optional) Capacitor polarity marking: adım 14, 1 resimden 1.
    • If the PCB is marked to avoid mis-installation, the flux will wash these marks off.
    • If you are unsure of the position of the capacitors, mark the polarity with a permanent marker. If the capacitors are incorrectly installed, they will explode when power is applied.
  15. Acer AL2216W Capacitor Replacement, Add flux to the capacitor leads: adım 15, 1 resimden 1.
    • If you do not have flux on hand, solder can be used. Some flux is difficult to clean if overused.
    • To prepare the board for capacitor replacement, add flux or solder.
  16. Acer AL2216W Capacitor Replacement, Remove the old capacitors: adım 16, 3 resimden 1. Acer AL2216W Capacitor Replacement, Remove the old capacitors: adım 16, 3 resimden 2. Acer AL2216W Capacitor Replacement, Remove the old capacitors: adım 16, 3 resimden 3.
    • Use of a Helping Hands is recommended to avoid soldering iron contact. If you do not have one, hold the board at an angle.
    • While a partial replacement may work, the remaining capacitors will fail. It is best to do them all while servicing the failed ones. Refer to this guide for a soldering "how to".
    • Move to a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat up each leg and remove it.
    • After removing the capacitors, clean up the old solder with a desoldering braid. Lift it with the iron when removing it.
  17. Acer AL2216W Capacitor Replacement, Installing brand new capacitors: adım 17, 1 resimden 1.
    • Check the capacitor polarity before soldering the new capacitors in. Incorrectly installed capacitors will explode with power applied!
    • Install the new capacitors. Check the polarity and bend the leads so they do not come loose during installation.
  18. Acer AL2216W Capacitor Replacement, Solder the new capacitors in: adım 18, 3 resimden 1. Acer AL2216W Capacitor Replacement, Solder the new capacitors in: adım 18, 3 resimden 2. Acer AL2216W Capacitor Replacement, Solder the new capacitors in: adım 18, 3 resimden 3.
    • Once the polarity is verified, solder the capacitors in. After installation, cut off any excess lead.
  19. Acer AL2216W Capacitor Replacement, Clean the flux off of the board: adım 19, 1 resimden 1.
    • After verifying there are no cold solder joints, clean the board with 91%+ Isopropyl alcohol, or denatured alcohol.
  20. Acer AL2216W Capacitor Replacement, Test the monitor: adım 20, 1 resimden 1.
    • Put the monitor back together and test the repair.
    Excellent guide. Really helped in getting the casing apart and pulling things off in the proper order to not damage anything. It turns out nearly every capacitor on mine was blown, so I instead just ordered a replacement board (which was cheaper than buying all new capacitors).
    gtxcrusader - Yanıt
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Nick
94.007 İtibar
59 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.677 adet Kılavuz yazıldı
28Kılavuz Yorumları
I did not replace the large capacitor on the Acer monitor yet. All other caps have been replaced. I may have to replace the FSPO55- ZP102A as it has a hot spot beside it. I don't know if the part number is right? Do know where I can buy it. Tom B
Thomas Brady - Yanıt
These older CCFL panels usually burn on the PCB by the inverter coil and main transformer (the Delta branded part, in this case). The LED monitors limit the failure points to the transformer.
It sounds like your PCB got burned from the heat by the transformer or the inverter coil. This is very common and the boards are designed to take it. However, if you are concerned you should buy a new power supply board altogether if that makes you more comfortable.
Nick -
In step 12, replacing the capacitors with ones with a different capacitance rating instead of using a capacitor rated for higher voltage makes no sense to me electrically. The capacitance rating is the important part, if you use a capacator rated for say 35 volts when the original is rated for 10 makes no difference whatsoever. the rating just means MAX voltage.
Brennan Gomolka - Yanıt
Thanks @nick! Just waiting for the parts to come in!
Aiden - Yanıt
@nick which one is the filter capacitor?
Aiden -
The big one on the AC side.
Nick -
@nick is it OK if I combine the exact replacement capacitors and the “upgraded” on the power supply? or do I only use original or upgraded?
Aiden -
It’s okay to use the matched and upgraded caps at the same time. The ones I upgraded were hard to find since they’re more or less obsolete.
Nick -
Ok thanks! reason why is I got all my replacements scrapping dead Power supplies. so I managed to get some and some others
Aiden -
@nick bridging some of the lines that are covering the board doesn’t matter does it? they dont seem to connect anything.
Aiden -
That’s a way to get extra groundplane with minimal cost. By design, it gets covered in solder during assembly. I wouldn’t leave solder on those.
Nick -
also one more thing. which capacitors do the upgraded ones replace?
Aiden -
@nick so not good if they bridged?
Aiden -
Yeah. It’s a bad idea to bridge it. The places the upgraded caps go are listed in the part descriptions as a note if it was replaced.
Nick -
OK. I didn’t expect to find the monitor I needed to replace on ifixit out of tons of others that are not. thanks for making the guide!
Aiden -
Most of the monitors people usually buy are low end and are rarely worth repairing or the owner is too lazy to bother because of how cheap a good one is today. I only ever see good monitors like Dell Ultrasharps in use by businesses.
On one hand it’s a waste but if I can get it and fix it for relatively little money I’ll try.
Nick -
@nick which one is the inverter capacitor?
Aiden -
The capacitor by the coil. Some revisions don’t have it.
Nick -
the one in step 12?
Aiden -
The one with the red box around it.
Nick -
@nick hasnt turned on. I only see a very dim red light from the power button and pressing it does nothing.
Aiden -
same as before. I did not replace all though. @nick
Aiden -
@captainsnowball And I figured out what the issue may have been almost 4 years later :-(. I assumed the Delta 00A supply was the common unit and common sense would dictate the information on the caps I have is specific to the 00A part, but that wasn’t the case.
It’s been fixed for a while, but the issue has been ongoing for a long time because it’s been patched to help rather then properly fixed. I’m going to keep it for cases like yours where you need a starting point, but it had to be clarified. The monitor really needs to come apart to be sure, so I may remove it as it isn’t definite and may vary.
Nick -
Thanks! Lets see if I can get this working.
Aiden - Yanıt
We changed only the three 25V 220uF capacitors (two of them looked broken), and the backlight was working again. Thanks for the description! Spent 0,24€ and around an hour for the fix. As a beginner in soldering:-)
If you have any further problems, replace the rest of the caps at the same time. That will sort out the problem if it isn’t caused by another failure.
Nick -
No power led when turned on. The capacitors showed on the top a warp - sign that they are blown up. Replaced all electrolyte capacitors on two monitors and the work fine. Have nice pictures but can't add them.
Heiko Schloesser - Yanıt
My monitor does not have the handy-dandy small screws in the back. It also lacks a larger prying point on the bottom edge. However, it seems to have a large screw UNDER the label in the center of the back case. Additionally, I am guessing it is an original model, not Ver 2 as there is NO version number on it. Manufacturers often hide screws under labels and rubber feet. If I am lucky, The case will open easily with the single screw removed. If it’s a version 1, the power supply may be a different design than what is in this set of instructions. May have to use my ifixit kit prying tools around the case edge if I decide it’s worth fixing; we’ll see.
Fred Kolbrener - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 155
Her zaman: 23,358
