Ana içeriğe geç
Amazon Echo Show 10 3rd Gen Motherboard Replacement
Leon Engle
Leon Engle ve 2 diğer katkıda bulunanlar
En son June 27, 2024 tarihinde güncellendi
Tahmin yok
Orta
This guide will walk you through the replacement process for the Motherboard found within your Amazon Echo Show 10 3rd Gen device. Refer to tweeter replacement guide as a prerequisite in order to get to motherboard.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Amazon Echo Show 10 3rd Gen Motherboard Replacement, Tweeter: adım 1, 2 resimden 1. Amazon Echo Show 10 3rd Gen Motherboard Replacement, Tweeter: adım 1, 2 resimden 2.
    • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
    • Remove the lid and set it aside.
  2. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 2, 1 resimden 1.
    • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
  3. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 3, 2 resimden 1. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 3, 2 resimden 2.
    • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
    • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
    • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
  4. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
  5. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 5, 2 resimden 1. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 5, 2 resimden 2.
    • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
    • Place the shell aside.
  6. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 6, 2 resimden 1. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 6, 2 resimden 2.
    • Rotate the device to lay on its side with the tweeter's exterior facing you.
    • Unhook the 3-pin connector attaching the tweeter to the base with your fingers. Hold it as close to the base of the cord as possible, and lift it directly up from the socket.
  7. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 7, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 10 mm screws attaching the tweeter to the main speaker base.
  8. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the tweeter.
    • Repeat the previous steps if you are removing the other tweeter.
  9. Amazon Echo Show 10 3rd Gen Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove the six 6.8 mm screws using a T6 Torx screwdriver.
    • Remove the metal bracket.
  10. Amazon Echo Show 10 3rd Gen Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Leon Engle
205 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Spring 2024 IUPUI, Team 1-3, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G3
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
hola modulo de wifi, esta integrado en la tarjeta madre?
Julio Guadamuz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 274
