Giriş
Use this guide if you’re experiencing issues with the Anker Soundcore Motion Boom Plus battery. If the speaker turns off unexpectedly or won’t power on, the battery may be drained, faulty, or in need of replacement.
Before continuing with this guide, rule out other possible causes. If the device isn’t charging, try using a different charging cable or power source to determine whether the battery is simply low. Also, check the charging port for any signs of damage.
This repair requires opening the device, so proceed with caution—some components may be sensitive to electrostatic discharge (ESD) or accidental damage. Consider using an anti-static mat or wrist strap to minimize ESD when repairing electronic devices.
If you notice the battery looks puffy or smells funny, the battery could be swollen. Be cautious if you encounter a swollen battery during disassembly and handle it carefully, as it poses a fire hazard.
Be sure to power off the speaker completely before beginning the repair to avoid electrical shock or damage to your speaker.
Neye ihtiyacın var
Insert an opening tool into the seam between the speaker grille and the chassis.
Pry the tool around the top, bottom, and sides until the grille fully releases.
Remove the grille.
Remove the four 11 mm Phillips screws securing the subwoofer.
Gently pull the subwoofer out of the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
