Ana içeriğe geç
Beats Studio First Generation Batteries Replacement
Oscar
Oscar ve 4 diğer katkıda bulunanlar
En son May 19, 2022 tarihinde güncellendi
2 dakika
Çok kolay
Öne Çıkan Öğrenci Kılavuzu
Don't worry, Dr. Dre is here! Changing the batteries is probably the easiest replacement procedure you can perform, so don't stress out and you'll be fine.
Neye ihtiyacın var
Parçalar
  1. Beats Studio First Generation Batteries Replacement, Identify the Left Speaker Housing: adım 1, 1 resimden 1.
    • The left speaker is the speaker that holds the batteries and does not have the power switch.
  2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: adım 2, 3 resimden 1. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: adım 2, 3 resimden 2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: adım 2, 3 resimden 3.
    • Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
    • Once the cap is loose, simply lift the cap out to reveal the batteries.
  3. Beats Studio First Generation Batteries Replacement, Batteries!: adım 3, 1 resimden 1.
    • Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
    cap does not turn
    venicecrazed - Yanıt
    PLEASE this is ugent for me, I've taken care of them alot but they dont turn on after i changed the batteries, I need to know whats wrong please contact me : vpereznatal@gmail.com
    I really need help
    Haruka Kyoto - Yanıt
    My cap does not turn. What is the secret?
    Roddy - Yanıt
    Where do i get a new battery for my beats solo 2 headphones
    Malla Sumanth - Yanıt
    My spring fell out where the battery goes in. Does someone know how to fix this?
    Noel Bindrich - Yanıt
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Oscar
1.175 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G18
4 Üyeler
11 adet Kılavuz yazıldı
29Kılavuz Yorumları
hi man you post is help me a lot thank you..God bless you
EL TIO SAM MARS - Yanıt
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
Nessa Upzs - Yanıt
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
John Coops -
Help,I'm trying to twist off battery compartment and it's not budging! Should I try and pry off w/screwdriver! Any ideas?
Kathy - Yanıt
hello jus curious if u got the cap to come off n how if so? any advice wld b greatly appreciated please n thank u
Randi -
Hi where can I get the replacement batteries for my beats S750
Diane Cairnes - Yanıt
mine just doesnt want turn
kooroshtaher - Yanıt
Hello this is beats sfudio?
Elmer Fabella - Yanıt
Hi can someone help me please I pulled out a spring in my headphones and I’m trying to fix it what will I need to do to fix it thank you
Maurice Brown - Yanıt
I pulled the spring out of my headphones I have no idea how to reconnect it can come someone tell me what to do please
Hey bro, my Headphone battery spring is broken what can I do???
Tobi David - Yanıt
Open the headphones, using steps 7,8,10,11 of “headphone jack” guide. Remove the broken spring, and solder in a replacement spring. They are AA size, you can get one from old toy or solar garden light. Make sure that connection does not stick up above red part, or black internal part will jam and earpiece will not swivel properly.
John Coops -
Very easy? I am kinda strong but opening this cap is impossible for me. I have Studio Wireless.
thelordofemails - Yanıt
Randi -
This instruction is not for studio wireless
pericopio santillan -
i CANNOT get the cap over the battery compartment will NOT budge for me….PLEASE help! Any advice/help wld b greatly appreciated…thank you
Randi - Yanıt
I see no one is answering on how to get the battery Compartment open. I cannot get the compartment to twistcounterclockwise at all. Help!
Gary - Yanıt
Very good instruction
pericopio santillan - Yanıt
So no1knows how 2get tight 2twist battery lid off it seems, n E 1please help out
lawrie079 - Yanıt
Hi I can't get the battery cover off .it's too tight
Margie Norris Norris - Yanıt
This is the worst design, why not make a slot where you can grip the cover and rotate in direction given in the instructions. Or include a tool or suggested tool to remove the cover when the two finger press and rotate counterclockwise does work…. Suppose the grip or force is not enough to remove the cover? Absolutely a terrible design!
Gregory White - Yanıt
Hi , I can’t twist the left hand ear piece , like it says , its too tight, and I used to be able to do it, no problem. Any ideas or suggestions as to how to get it undone? I don’t remember it being so difficult to unlock the cap! thank you
Ann
annlonergan - Yanıt
I can't get it either. Just forcefully twist in off?
Robert Teller -
HOW TO remove the battery cover - get some rubber sheet sold for “anti-slip mat” from local variety store. The material is cut with scissors and usually used to line drawers with (stops items sliding). Also you can get small pieces in kitchen shops that are sold as “jar and bottle gripper” which you use in your hand to open a tight jar. With the rubber between fingers and battery cover, it is easy to rotate it like shown in this guide. After you open it, place some silicone grease on the surfaces so it slides easier. Do not use vaseline, wd-40 etc… only silicone grease
John Coops - Yanıt
If you can’t get the cover off easily then I recommend checking the version of headphones you have.
My Beats Wireless (which I thought were of this design) are the original version 1. In the box the instructions indicate that the batteries are 2x AAA rechargeables……and I spent a good few hours almost destroying the left earpiece outer cover trying to ‘rotate it’ off as they show in the diagrams, except….the earpiece doesn’t rotate and the battery is a 602030 3.7v 300mAh LiPo.
The only left-side earpiece that does rotate is the one with two very small ‘outdents’/nobbles at the 3 o’clock and 9 o’clock position on the outer cover. If yours doesn’t have these then the battery type is the 3.7v and no amount of twisting will ever take the cover off. See this video instead…..
https://www.youtube.com/watch?v=oahpflnJ... (with thanks to ‘Joe’s Gaming & Electronics’)
Wodger - Yanıt
You are a “Beats” saver ( literally ) … 3 Apple specialists could figure it out. Now I can cancel tomorrow’s appointment at the Genius Bar to buy a new set. What a relief!
Loredana Della Vedova - Yanıt
GENIUS!!! Thank you SO much!! You ROCK!
Janet McCoid - Yanıt
I tried all the suggestions to GET THE CAP OFF... ended up finally just putting a fingernail under each slot (only the left ear has these 2 grip spots) and turning them counterclockwise with nail. Then just tapped the left side upside down and it finally just popped off! It is just as hard to get back on
KC Florline - Yanıt
Heck yes! Such an easy fix! Too freaking easy! Thanks!
prestonsalonzo@outlook.com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 44
Son 30 gün: 247
Her zaman: 149,727
