Ana içeriğe geç
Cambridge SoundWorks OontZ Angle Plus Battery Replacement
Artem Nykolenko
Artem Nykolenko ve 5 diğer katkıda bulunanlar
En son January 29, 2018 tarihinde güncellendi
Tahmin yok
Orta
Use this guide to replace the battery.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Cambridge SoundWorks OontZ Angle Plus Battery Replacement, Lower Casing: adım 1, 2 resimden 1. Cambridge SoundWorks OontZ Angle Plus Battery Replacement, Lower Casing: adım 1, 2 resimden 2.
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Battery Replacement, Battery: adım 2, 1 resimden 1.
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 3, 1 resimden 1.
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 4, 1 resimden 1.
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 6, 1 resimden 1.
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 7, 1 resimden 1.
    • With some force, push the motherboard straight in toward the center of the device.
    No need to remove board. De-solder wire from battery.
    BNaction - Yanıt
  8. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 8, 1 resimden 1.
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Battery Replacement: adım 9, 1 resimden 1.
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Artem Nykolenko
203 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
4Kılavuz Yorumları
Nice, thank you. I have to find the new battery. Any suggestions for suppliers?
pokopoko - Yanıt
Where do you get a replacement battery & what kind is it exactly please?
Tobhiyah Monroe - Yanıt
Of course the “guide” wouldn’t give the pertinent information (detailed replacement battery size) needed to actually complete the task at hand….
Frank Brauer - Yanıt
Had to look all over for this info but this is apparently the right stuff: The battery is a 3.7 V CR18650 (be sure you get at least 2200mAH) and is available from Amazon for around 4/$30. Alternatively,, you could also go to any Home Depot and take a discarded power/driver battery pack out of the recycling bin (the sales people have no problem). Take it home, open it up, and there you have upwards of 12 of these very same batteries inside, and usually 10 out of the twelve are perfectly good. People throw them out/recycle them when one or two cells go bad and the pack can recharge. (Big Thanks to YouTube user R. Sauder for this info.)
Dewar Grady - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 6,828
