Ana içeriğe geç
Cuisinart DFP-14BCN Switch Replacement
Sonya Dick
Sonya Dick ve 3 diğer katkıda bulunanlar
En son December 22, 2016 tarihinde güncellendi
20 - 25 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
A broken switch means electricity is not flowing through your device. Removing and replacing this component requires soldering. Check out this soldering guide for instructions.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Cuisinart DFP-14BCN Switch Replacement, Bowl: adım 1, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Bowl: adım 1, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement, Bowl: adım 1, 3 resimden 3.
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Switch Replacement: adım 2, 1 resimden 1.
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
    The little white thing that pushes down broke
    Mr. potato - Yanıt
  3. Cuisinart DFP-14BCN Switch Replacement: adım 3, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 3, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 3, 3 resimden 3.
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Switch Replacement: adım 4, 1 resimden 1.
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Switch Replacement: adım 5, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 5, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 5, 3 resimden 3.
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
    It seems so simple and obvious. Thanks for your help!!!
    Carrie Shirley - Yanıt
  6. Cuisinart DFP-14BCN Switch Replacement, Back Casing: adım 6, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Back Casing: adım 6, 2 resimden 2.
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Switch Replacement: adım 7, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 7, 2 resimden 2.
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Switch Replacement: adım 8, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 8, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 8, 3 resimden 3.
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Switch Replacement: adım 9, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 9, 2 resimden 2.
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Switch Replacement, Buttons: adım 10, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Buttons: adım 10, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement, Buttons: adım 10, 3 resimden 3.
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Switch Replacement: adım 11, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 11, 2 resimden 2.
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Switch Replacement: adım 12, 1 resimden 1.
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Switch Replacement: adım 13, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 13, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 13, 3 resimden 3.
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
  14. Cuisinart DFP-14BCN Switch Replacement, Switch: adım 14, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Switch: adım 14, 2 resimden 2.
    • Desolder the white, black and red connections from the switch by using a soldering iron.
    • Refer to the soldering guide for extra help.
    • For reassembly, the new switch's connections will have to be soldered on.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sonya Dick
352 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G3
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,622
