Ana içeriğe geç
Dell G15-5510 Gaming Battery Replacement
Neye ihtiyacın var
  1. Dell G15-5510 Gaming Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 1. Dell G15-5510 Gaming Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four screws securing the back cover.
    • Two 8 mm screws
    • Two 5.8 mm screws
    • Loosen the four captive screws.
  2. Dell G15-5510 Gaming Battery Replacement, Unclip the front corners: adım 2, 2 resimden 1. Dell G15-5510 Gaming Battery Replacement, Unclip the front corners: adım 2, 2 resimden 2.
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry upward to release clips holding the cover in place.
    • Listen for a loud click to indicate a clip being released.
  3. Dell G15-5510 Gaming Battery Replacement: adım 3, 2 resimden 1. Dell G15-5510 Gaming Battery Replacement: adım 3, 2 resimden 2.
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5510 Gaming Battery Replacement, Remove the back cover: adım 4, 3 resimden 1. Dell G15-5510 Gaming Battery Replacement, Remove the back cover: adım 4, 3 resimden 2. Dell G15-5510 Gaming Battery Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5510 Gaming Battery Replacement, Disconnect the battery: adım 5, 3 resimden 1. Dell G15-5510 Gaming Battery Replacement, Disconnect the battery: adım 5, 3 resimden 2. Dell G15-5510 Gaming Battery Replacement, Disconnect the battery: adım 5, 3 resimden 3.
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5510 Gaming Battery Replacement, Unfasten the battery: adım 6, 2 resimden 1. Dell G15-5510 Gaming Battery Replacement, Unfasten the battery: adım 6, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 4.1 mm-long screws securing the battery.
  7. Dell G15-5510 Gaming Battery Replacement, Remove the battery: adım 7, 3 resimden 1. Dell G15-5510 Gaming Battery Replacement, Remove the battery: adım 7, 3 resimden 2. Dell G15-5510 Gaming Battery Replacement, Remove the battery: adım 7, 3 resimden 3.
    • Pull the battery towards the top of the laptop to separate it from its plastic shell.
    • Remove the battery.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
2 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
164.335 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.715 adet Kılavuz yazıldı
2Kılavuz Yorumları
needs extra slide about removing battery ribbon cable from the battery itself and attaching it to the replacement. After some research I found you're supposed to pry it upwards and NOT pull it outwards
Erik Cui - Yanıt
donde comprarla o pedirla
HADES H - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 44
Son 30 gün: 250
Her zaman: 4,752
