Ana içeriğe geç
Dell Inspiron 3501 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: adım 2, 2 resimden 1. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: adım 2, 2 resimden 2.
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: adım 3, 2 resimden 1. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: adım 3, 2 resimden 2.
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: adım 4, 3 resimden 1. Dell Inspiron 3501 Battery Replacement, Remove the back cover: adım 4, 3 resimden 2. Dell Inspiron 3501 Battery Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: adım 5, 2 resimden 1. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: adım 5, 2 resimden 2.
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: adım 6, 2 resimden 1. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: adım 6, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: adım 7, 3 resimden 1. Dell Inspiron 3501 Battery Replacement, Remove the battery: adım 7, 3 resimden 2. Dell Inspiron 3501 Battery Replacement, Remove the battery: adım 7, 3 resimden 3.
    • Lift the battery straight out of its recess and remove it.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
2 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
164.332 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.706 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 126
Her zaman: 2,222
