Ana içeriğe geç
Dell Latitude 7490 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Dell Latitude 7490 Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Dell Latitude 7490 Battery Replacement, Flip your laptop over: adım 2, 1 resimden 1.
    • Flip your laptop over so the rubber feet strips are facing up.
  3. Dell Latitude 7490 Battery Replacement, Loosen the captive screws: adım 3, 2 resimden 1. Dell Latitude 7490 Battery Replacement, Loosen the captive screws: adım 3, 2 resimden 2.
    • Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
  4. Dell Latitude 7490 Battery Replacement, Insert an opening pick: adım 4, 3 resimden 1. Dell Latitude 7490 Battery Replacement, Insert an opening pick: adım 4, 3 resimden 2. Dell Latitude 7490 Battery Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Insert the long side of an opening pick between the top right corner of the back cover and frame.
    • Pry the back cover up to release the clips securing the top right corner.
  5. Dell Latitude 7490 Battery Replacement, Release the clips: adım 5, 3 resimden 1. Dell Latitude 7490 Battery Replacement, Release the clips: adım 5, 3 resimden 2. Dell Latitude 7490 Battery Replacement, Release the clips: adım 5, 3 resimden 3.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Dell Latitude 7490 Battery Replacement: adım 6, 3 resimden 1. Dell Latitude 7490 Battery Replacement: adım 6, 3 resimden 2. Dell Latitude 7490 Battery Replacement: adım 6, 3 resimden 3.
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Dell Latitude 7490 Battery Replacement, Remove the back cover: adım 7, 3 resimden 1. Dell Latitude 7490 Battery Replacement, Remove the back cover: adım 7, 3 resimden 2. Dell Latitude 7490 Battery Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press down firmly around the perimeter to engage all the clips.
  8. Dell Latitude 7490 Battery Replacement, Disconnect the battery: adım 8, 2 resimden 1. Dell Latitude 7490 Battery Replacement, Disconnect the battery: adım 8, 2 resimden 2.
    • Grip the plastic tab on the battery connector and pull straight up to disconnect it.
    • During reassembly, align this connector over its socket and press down until it clicks into place. If it doesn't connect, re‑align it and try again.
  9. Dell Latitude 7490 Battery Replacement, Unfasten the battery: adım 9, 2 resimden 1. Dell Latitude 7490 Battery Replacement, Unfasten the battery: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 5.7 mm‑long screws securing the battery.
  10. Dell Latitude 7490 Battery Replacement, Remove the battery: adım 10, 3 resimden 1. Dell Latitude 7490 Battery Replacement, Remove the battery: adım 10, 3 resimden 2. Dell Latitude 7490 Battery Replacement, Remove the battery: adım 10, 3 resimden 3.
    • Lift the top edge of the battery.
    • Slide the battery's bottom edge out of its recess in the frame and remove the battery.
  11. Dell Latitude 7490 Battery Replacement, Reassembly information: adım 11, 3 resimden 1. Dell Latitude 7490 Battery Replacement, Reassembly information: adım 11, 3 resimden 2. Dell Latitude 7490 Battery Replacement, Reassembly information: adım 11, 3 resimden 3.
    • During reassembly, slide the four plastic tabs on the bottom edge of the battery into their recesses on the frame before securing the battery.
  12. Dell Latitude 7490 Battery Replacement, Remove the battery cable: adım 12, 3 resimden 1. Dell Latitude 7490 Battery Replacement, Remove the battery cable: adım 12, 3 resimden 2. Dell Latitude 7490 Battery Replacement, Remove the battery cable: adım 12, 3 resimden 3.
    • If your replacement battery doesn’t come with a cable preinstalled, you’ll have to transfer your original cable to the new battery.
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Flip the battery over and lay it on a clean working surface.
    • Use one hand to secure the battery.
    • Use your other hand to firmly pull the battery connector out of its socket on the bottom edge of the battery.
    • Remove the battery cable from its recess between the two battery cells.
    • During reassembly, transfer the battery cable to your new battery, making sure the cable is snug between the battery cells.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
54.989 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.303 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 76
Son 30 gün: 305
Her zaman: 2,275
