Ana içeriğe geç
Dell XPS 13 9305 Battery Replacement
Neye ihtiyacın var
  1. Dell XPS 13 9305 Battery Replacement, Remove the back screws: adım 1, 2 resimden 1. Dell XPS 13 9305 Battery Replacement, Remove the back screws: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
  2. Dell XPS 13 9305 Battery Replacement, Release the clips: adım 2, 2 resimden 1. Dell XPS 13 9305 Battery Replacement, Release the clips: adım 2, 2 resimden 2.
    • At each corner, insert an opening pick between the back cover and the device body.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Dell XPS 13 9305 Battery Replacement, Remove the back cover: adım 3, 3 resimden 1. Dell XPS 13 9305 Battery Replacement, Remove the back cover: adım 3, 3 resimden 2. Dell XPS 13 9305 Battery Replacement, Remove the back cover: adım 3, 3 resimden 3.
    • The edges of the cover are very sharp. Use caution when handling this panel.
    • Lift the front edge of the cover away from you.
    • Some clips may release during this step. If the cover is stuck, move it side to side to help release additional clips.
    • Remove the back cover from the laptop.
  4. Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: adım 4, 3 resimden 1. Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: adım 4, 3 resimden 2. Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: adım 4, 3 resimden 3.
    • Push the battery connector out of its socket using the pointed end of a spudger.
    • Push the small tabs on the side of the connector to avoid damaging the cables.
  5. Dell XPS 13 9305 Battery Replacement, Unfasten the battery: adım 5, 2 resimden 1. Dell XPS 13 9305 Battery Replacement, Unfasten the battery: adım 5, 2 resimden 2.
    • Use a Phillips screwdriver to remove the five screws securing the battery:
    • Four 2.4 mm-long screws
    • One 4.4 mm-long screw
  6. Dell XPS 13 9305 Battery Replacement, Remove the battery: adım 6, 3 resimden 1. Dell XPS 13 9305 Battery Replacement, Remove the battery: adım 6, 3 resimden 2. Dell XPS 13 9305 Battery Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Lift the battery straight out of its recess and remove it.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
2 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
124.729 İtibar
582 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.303 adet Kılavuz yazıldı
Bir Yorum
This replacement was extremely simple. I have some experience from years ago when I replaced laptop parts during an internship, but was worried things might have gotten a lot more complicated in the 15+ years since. But it was super easy. This guide + the toolkit made it an absolute breeze. I was actually surprised how easy this was. I'm convinced almost anyone can do this. Thanks for the tutorial!
Bono - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 43
Son 30 gün: 205
Her zaman: 2,060
