Ana içeriğe geç
Dell XPS 15 9560 Battery Replacement
Neye ihtiyacın var
    1. Dell XPS 15 9560 Battery  Replacement, Back Panel: adım 1, 1 resimden 1.
      • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
      • Shut the laptop down.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 15 9560 Battery  Replacement: adım 2, 1 resimden 1.
      • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 15 9560 Battery  Replacement: adım 3, 1 resimden 1.
      • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
      FixBot'a Sor
      Yorum Ekle
    4. Dell XPS 15 9560 Battery  Replacement: adım 4, 1 resimden 1.
      • Use a scribe to remove the bottom base cover from the backplate.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 15 9560 Battery  Replacement, Battery: adım 5, 1 resimden 1.
      • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 15 9560 Battery  Replacement: adım 6, 1 resimden 1.
      • Use your fingernails to gently "walk" the battery connector directly out of its socket.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 15 9560 Battery  Replacement: adım 7, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
12 farklı kişi bu kılavuzu tamamladı.
Jada Houser
884 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G5
4 Üyeler
33 adet Kılavuz yazıldı
1Rehber Yorum
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 184
Her zaman: 15,282
