Giriş
Follow this guide to replace a broken or drifting joystick (aka thumbstick or analog stick) for the PlayStation DualSense v2 controller. If you experience persistent stick drift, it's likely due to a worn out joystick module.
This repair requires intermediate soldering skills. Desoldering the joystick module is difficult, but can be done with some patience.
This guide shows you how to cut apart the joystick module so you can desolder the pieces individually with a soldering iron. The procedure will destroy the existing joystick module. If you have a hot air station, you'll have an easier time desoldering the joysticks.
Consider replacing the drifting joystick with a TMR joystick module to fix stick wear and drift permanently.
Neye ihtiyacın var
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
Insert the flat end of a spudger into the gap above the L1 button.
Pry the spudger upward to remove the L1 button.
Insert the flat end of a spudger into the gap above the R1 button.
Pry the spudger upward to remove the R1 button.
Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
Use your hands to carefully pull the rear case off of the controller.
Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
Don't completely remove the ribbon cable yet.
Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
Carefully guide the joysticks through the front case and lift the motherboard out.
Bu adımda kullanılan alet:FixHub Smart Soldering Iron$79.95
Flip the motherboard and midframe over to access the red and black vibration motor wires.
Use a soldering iron to disconnect the vibration motor wires from the motherboard.
Use your fingers to remove the left and right joystick covers from the motherboard.
Use your fingers to remove the speaker and foam pad from the motherboard.
Four anchor joints
Six joints connecting the two potentiometers
Four joystick push-button joints
Insert the tips of a pair of angled tweezers between the top edge of a potentiometer and the joystick frame.
Pivot the tweezers down to bend the top edge of the potentiometer away from the joystick frame.
Bu adımda kullanılan alet:Helping Hands$9.99
Secure the motherboard with helping hands or a similar tool so that the potentiometer solder joints face up.
Bu adımda kullanılan alet:No-Clean Flux$4.95
Apply flux to the three solder joints securing one of the potentiometers.
Press the soldering iron tip against a potentiometer joint to heat it.
Once the joint's molten, use a desoldering pump to suck away the solder.
Repeat the heating and sucking procedure a few times on the same joint to remove as much solder as possible. Be sure not to heat the joint longer than 15 seconds at a time.
Use flush cutters to cut the top corners of the joystick frame.
Secure the motherboard so that the solder joints face upward.
Use the soldering iron to heat a solder joint securing one of the frame anchors.
Once the solder is molten, use pliers to grab and pull the frame anchor out of its through-hole.
Repeat the procedure to remove all four anchor joints.
Slide the flat end of a spudger under the joystick module's plastic base.
Slowly pry up the base to bend and break it away from the motherboard.
Remove the plastic base.
Secure the motherboard so you can access both sides of it.
Use the soldering iron to heat one side of a through-hole.
Use a desoldering pump on the opposite side of the through-hole to suck up any remaining solder.
If needed, use solder wick to remove any residual solder.
Repeat this for all through-holes and both sides of the motherboard.
Apply a few drops of high concentration (>90%) isopropyl alcohol to the top side of the motherboard, where the new joystick module will sit.
Use a cotton swab or a soft brush and cloth to wipe away the flux residue.
Place the replacement joystick module onto the motherboard so that all the pins thread through the through-holes.
Gently press the joystick onto the board so that the joystick sits flush with the board surface.
Apply a few drops of high concentration (>90%) isopropyl alcohol to the motherboard wherever you can see flux residue.
Visually inspect your work:
Make sure each solder joint looks well-formed.
Make sure no solder joints are shorting each other.
Congratulations! You've replaced the controller's joystick and, in the process, leveled up your soldering skills.
To reassemble the controller, go to this step and follow the instructions in reverse order.
You'll need to run the calibration tool to calibrate the new joystick.
16 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Is there a calibration element post install of the new modules?
Great instructions, very easy to follow. (Although I wouldn't recommend that this be anyone's first soldering project; desoldering any through-hole part with a bunch of pins like those joysticks is a pain.)
Also a big thank you Sony for making such a well-designed controller that's reasonably easy to disassemble and re-assemble. (No adhesive! Not a million different types of screws to keep track of!)
@tim1724 i had to put a little bit of glue on the speaker sponge to stick it back, otherwise you're right, easy peasy lemon squeezy!
